vom 1.8TD Endura E ist er gleich.. laut infos von einigen die schonmal auf TD umgebaut haben The focus had the Endura-DI engine (A direct-injection version of the Endura-DE). The basic block is the same so this can be fitted to a Mk3, however the fuel pump is fully electronic and so the entire engine management system is require. This also applies to the later TDCi engine (A common-rail version of the Endura-DI). denn das wird dann mein motor ^^
